codeplug and feature set are different
ASTROAL
brooklyn ny
Made changes to my astro saber lll,went to write to the radio and got message"codeplug and
feature set are different"How do I resolve this issue?.
scanfan03
Houston, Texas
I don't have any experience with the saber, but I do have experience with MTX8000s and Spectras. What I would do is re-read the saber, edit the codeplug again and then try to re-write it into the radio.
gary123
Since you havent been able to write your changes the first thing to do is read and save your current codeplug configuration. It sounds like you have enabled a feature (mdc decode,trunk or something similar) in the file you want to write to the radio, I suspect you have a codeplug for a different model you are trying to load. If you are trying to load conventional info go to the conventional personality field and make the changes you want. trunking is a bit more complex as you will need a system key to edit any trunking parameters.
b7spectra
EMS Dispatcher
Cobb County, GA
What probably happened is that you set something up in the software that is not compatible with the radio. i.e. doing STAR burst and the radio will not support it.
scanfan03
Houston, Texas
Being a novice,how do you edit the codeplug?
Editing the codeplug means changing frequencies and what not. The file that goes into the radio is called the codeplug, so anything you change in that file is editing the codeplug. Like people have already said it sounds like a feature is enabled in the codeplug that isn't supported by the radio. So start with a known working codeplug (the one in the radio) and work your way from there.
ASTROAL
brooklyn ny
CPS rss says last write to radio was programed
in Dos,so I used the dos 09.03 program and was able
to make changes and then write to the radio.
