codeplug for CDM 1550 LS needed
70cutlass442
Im looking for a codeplug for a CDM 1550 LS Model number : AAM25RKF9DU5AN I just bought one and there is a password on it... PM me for EMail, any help would be great!!
justinwj86
St George, NB
I Also have a Motorola CDM1550-LS Model AAM25RKF9DU5AN that has a password on it that i have bought on ebay. I'm in need of a codeplug or some to help me. Thanks
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The information you seek has been here for nearly a year. A quick search and you would have found: http://forums.radioreference.com/motorola-forum/305060-cps-6-12-09-a.html
There are also detailed instructions on this over on the batboard and also on communications.support.
Search tags: The Professional or Waris Series of radios includes:
HT750 HT1250 HT1550
EX500 EX600 EX560 EX650 PR860
CDM750 CDM1250 CDM1550
HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with HVN9025 CPS.
For what it is worth, the answer to this has been available on these forums for several years. Some simple searching quickly finds these things.
SteveC0625
It may be easier to go to batlabs and search under password bypass, or to supercodeplugs.com for your codeplug. My software ignores all passwords, the software has been rewritten to do a jump command when encountering a password.
Mine too. In one of the threads on the batboard, I listed an easy way to determine the code to edit, regardless of precise version of the Professional Series CPS. It's just two characters that need to be changed, and they are part of a unique string of characters that appears only once anywhere in the code. Search, replace, and save. It's as simple as that.
I have both the Pro and Commercial CPS's modified for this.
justinwj86
St George, NB
I already have acquired the cps from MOL. What I meant was the things I need to change for the cps to work. Can it be done through resource hacker?
SteveC0625
Look, it's a simple edit and save of the CPS executable. All the info to do this is over on the batboard. All you need is a hex editor. You change two characters and save the file. Then you have the password bypass.
Go to the batboard, look back through my posts. You will quickly find several threads that contain detailed and specific instructions for modifying your Professional Series CPS for the password bypass. (Ignore the threads about the Commercial Series bypass.)
I can't make this any easier for you.
