It doesn't say anything how well it handles large signals. Go to Ebay and search for PGA103+ and you will find lots of amplifiers that are good. They all have the same specification and its only the mechanics that differ, how they are powered and so on. If you got mains power in the attic you can buy the cheapest amplifier that can be powered from an USB cable and a cheap 5volt cellphone charger. You'll need to get adaptors to fit antenna and the coax F connector, or get the more prefered pig tails with the correct type of connectors.
Don't forget the variable 0-20dB attenuator. Get one with F connectors and connect the downstairs coax to that and the other end of the attenuator to the scanner.
FM broadcast filter are optional but never hurts.
I've never heard of that happening. If you transmit nearby, a couple of feet, you can blow out the input of a scanner but not when using an antenna amplifier. Amplifiers cannot produce enough signal level to hurt a scanner, the amplifier will blow first before that could happen.
/Ubbe
