That would depend on the front. A sharp enough temperature change could cause a temperature inversion and that could cause the signal to be refracted back down toward the surface so that a system could be heard hundreds of miles away. Although this is quite common on VHF, this will NOT happen on 800 MHz with the majority of fronts.
I have, in fact, heard stories about having to shut down parts of the Delaware system due to ducting across the water from NJ. Yes it doesn't happen that often, but it certainly does.
I've monitored the Delaware 800 MHz TRS from Cape Cod, MA on numerous occasions. It's by and large a water path but it is certainly the result of ducting.
