Collapsable Stock Antenna Length
TongSlinger
Longtime Listener
35.393528, -99.467468
Quick question, When tuning 857-858 Mhz with a stock scanner, Can i collapse the antenna to the proper length, or is it tough cookies? If so, What would be the proper length for that frequency? Look like 3.25" for 1/4 Wave or 6.5" for a 1/2 Wave. Look right?
ka3aaa
middletown, pa.
you only need one section of antenna or aprox 6 inches for that band. Shrink it totally and you will be good.
wowologist
Certifiable
CM87
Theirs actually a lot more variables then one would realize when you are dealing with a receive only situation, the two things that are constant for clear signal acquisition are line of sight/obstructions AND the antenna's height above ground. If your are on a second story of a house say and you have a clear line of sight to the transmitting tower you have a ton of advantages and it's not going to matter what length that antenna is, your going to reiceve the signal or not. Then again if your on the bottom side of an apartment complex with 20 miles and 2 large hills in between you and the tower, your going to have to add some things to achieve a better/best signal, once again it wont matter what length you put that antenna. Here's the trick I use - coat hanger in a loop and I can hear everything I want to hear...if I cant I need to start to think about exterior mounting and QUALITY coax runs AND their length/vs loss/signal acquisition.
nd5y
Wichita Falls, TX
3 1/2 inches or so (1/4 wave) will work best. 1/2 wave antennas with the feedpoint at one end are high impedance and require a matching network.
