TRX-2: Color for Service
BruceMichaels
Not "Some People"
Flying Over You
Quick question. I'm using color code FFFF00 for the color YELLOW to display when a specific channel is in use. It only comes up as GREEN! Anyone able to get it to turn yellow?
ecarvalho
I use the software and the color I pick is usually the same in the LED
AKJohnny
Scanner Addict
Kendall County, IL
I and others have same issue. Had a trx-2 with same issue that I returned for other reasons, and now have a different trx-2 and a trx-1 both with same led issues. Some show up correct, but many don't.
Check out this thread for some other color codes:
https://forums.radioreference.com/whistler-scanners/350855-ezscan-led-color-codes.html
