Colorado Railfans
datainmotion
Colorado
I have logged a number of AAR channel frequencies since last night that are not in the db for CO. They are:
04 - 160.050 (7 hits)
31 - 160.575 (2 hits)
33 - 160.605 (12 hits)
37 - 160.665 (14 hits)
41 - 160.725 (2 hits)
43 - 160.755 (324 hits)
46 - 160.800 (1 hit)
48 - 160.830 (3 hits)
59 - 160.995 (4 hits)
76 - 161.250 (116 hits)
78 - 161.280 (22 hits)
79 - 161.295 (707 hits)
80 - 161.310 (271 hits)
96 - 161.550 (1 hit)
In addition, I believe I may have logged some narrowband channels as well:
??? - 160.2075 (6 hits)
153 - 160.9125 (1 hit)
166 - 161.1075 (1 hit)
And last but not least, an oddball that I'm assuming is not part of any AAR channel:
160.225 (8 hits)
Any help on what these might be would be appreciated so they can be added to the db. :)
jimmnn
Colorado
From my rail friends;
04 - 160.050 (7 hits) No idea, never seen this used
31 - 160.575 (2 hits) BNSF Maintenance of Way in the Denver Terminal Area
33 - 160.605 (12 hits) UP PBX input (Lookout Mtn Golden, Julesberg, Cheyenne, WY, Mt Buckhorn, Miliken) as well as UP Maintenance of Way Car to Car
37 - 160.665 (14 hits) BNSF PBX Input (Denver, Angora, Wray, Trinidad) as well as Colorado and Wyoming Railroad for use at Rky Mtn Steel in Pueblo CO
41 - 160.725 (2 hits) UP Maintenance of Way
43 - 160.755 (324 hits) UP Switching Channel North Yard Denver
46 - 160.800 (1 hit) No uses noted Colorado
48 - 160.830 (3 hits) No uses noted Colorado
59 - 160.995 (4 hits) No uses noted Colorado
76 - 161.250 (116 hits) BNSF Switching (Industrial Jobs Denver, Golden Yard, Denver Yard, Fort Collins Yard)
78 - 161.280 (22 hits) BNSF Yard Denver
79 - 161.295 (707 hits) BNSF Switching 31st, 32nd, and 38th Street Yard Denver
80 - 161.310 (271 hits) UP Car Dept (used North Yard Denver to inspect trains)
96 - 161.550 (1 hit) Manitou and Pikes Peak Railroad at Pikes Peak as well as Amtrak uses while in Denver Terminal
??? - 160.2075 (6 hits) New ground here no idea
153 - 160.9125 (1 hit) New ground here no idea
166 - 161.1075 (1 hit) New ground here no idea
160.225 (8 hits) Doesn’t look correct
Hope this helps a little.
Jim<
abqscan
DataBase Administrator
Moderator
AOA
Some to add from my logs...
I have heard voice on all of these freqs.
160.445
160.47
160.65
160.74
160.775
160.8
160.92
161.1
161.16
161.145
161.415
datainmotion
Colorado
Excellent! Thanks Eric.
160.445 445 not an AAR freq (440 is AAR 22)
160.47 in the db as UP24
160.65 in the db as BNSF36
160.74 in the db as UP42
160.775 775 not an AAR freq (770 is AAR 44)
160.8 AAR 46 (unknown user) that I logged as well
160.92 in the db as UP54
161.1 in the db as BNSF66 (very busy!)
161.16 in the db as BNSF70
161.145 in the db as UP69
161.415 in the db as BNSF87
datainmotion
Colorado
Additional hits...
Here's some more:
160.230 (6 hits)
160.275 (34 hits)
160.395 (9 hits)
161.130 (1 hit)
jeffreyinberthoud
Banned
BERTHOUD COLORADO
I sent in some rail freqs a wile back I think are not all these in the database,If not I guess if we know they are used here they should be right?
jimmnn
Colorado
160.445
160.47
160.65
160.74
160.775
160.8
160.92
161.1
161.16
161.145
161.415
160.445 UP Road – Rocky to East Portal, rocky to AEC Spur
160.47 UP Road -
160.65 BNSF Road – Joint line Denver-Pueblo
160.74 UP Road
160.775 UP Switching – North Yard
160.8 No uses noted Colorado
160.92 UP Road – Joint Line Denver-Pueblo, Denver Terminal Area
161.1 BNSF Road – Denver Area, Denver-Brush, Denver to Englewood,
161.16 BNSF Road – Denver-Golden, Denver-Cheyenne
161.145 UP Road – Speer, WY to Hazletine, CO (just south of Brighton), LaSalle to Fort Collins, Sand Creek to Valmont (Boulder)
161.415 No uses noted Colorado
Jim<
datainmotion
Colorado
Still wondering about 160.775 since it's not an AAR frequency...
Also, from your post it appears we need to revisit the Colorado RR listings in the db.
Northeast Nebraska
A lot of the time, if there is a crew using a channel that is assigned for use in a particular yard/job such as 6666-161.100, and is very congested, they may choose to use another frequency to get away from the radio traffic.
That may explain the "No uses noted in Colorado" attached to the mystery frequencies.
We would do this on a fairly regular basis while we did local switching over the BNSF Creston Sub around Omaha, again to get away from the congestion, not to mention, having too much radio traffic can become a safety concern.
So railroad crews can just about go anywhere over the AAR channels provided they look in the timetable to determine which frequency to use and to insure they are not on another "foreign RR" frequency, PBX assigned channels, etc.
datainmotion
Colorado
Rich,
Thank you very much for the clarification. Is it possible that some of these "temporarily itinerant" AAR channels could get heavy usage even on a weekend?
Mike
