Columbia MURS2 Handheld antenna mod?
mirrorshades
This may be a longshot. Some years back, I ran across a website where someone described modding an old Columbia MURS2 HT by removing the fixed antenna and attaching a connector instead (I don't recall if it was BNC or SMA). Obviously this allowed more efficient antennas to be attached, which improved the performance.
I cannot for the life of me find this page anymore. Does this ring a bell for anyone?
alcahuete
Antelope Acres, California
I have found a ton of pics, but all of them are with the antenna attached.
Take a picture looking at the antenna connector (sans antenna) and post it here.
Judging by the pics I found, it is absolutely 100% NOT a BNC connector. Likely SMA, but there is SMA Male and SMA Female depending on how it's set up.
mirrorshades
Sorry I guess I wasn't clear. The antenna on the unit is attached permanently, it's a part of the case itself. Someone posted instructions on how he cut the attached antenna off and replaced it with a BNC or SMA connector that let him use other commercially available antennas instead (for better performance).
n1nte
Holland, MA
That information was on the old MURS-OPEN@yahoogroups.com. The author was August Hoecker, W8MIA. I couldn't find it either. It was a BNC connector that was fitted into the area where the antenna goes into the radio body. You might want to email him to see if he has the original information.
It should be easy enough to do. Remove the antenna and wire in a coaxial connector.
Splitting hairs, here, but technically that's a modification to the radio and would void the type certification that makes it legal to use on MURS.
No, the FCC isn't going to come roaring up to your house and bust you...
