Columbus Airport Authority Police
k4sgt
They had an analog 800MHz repeater at the airport that broke. Now I think they are just using simplex. You should hear them here if you have a big enough antenna and/or are close to the airport.
854.1625
856.5625
Schoolcop
Gales Ferry
Thanks I going to be down there on vacation and will be near the airport so I will give the freqs a try. Again thanks!
Schoolcop
Gales Ferry
One other quick question is the airport fire dept on the same freqs or are they on a different system I dont see anything for them on the data base so I was wondering if they maybe were run by the Columbus Fire Dept?
k4sgt
Fire and security are both using the freqs listed above. They have some radios that are programmed to tqlk kn the Columbus 800 system for interoperability, but the airport operates on simplex.
