comet gp-9nc uhf/vhf - adding radials
wqzw301
Hello all,
For a couple of years, I have been using a Laird FG series uhf antenna, for my repeater.
Now I am adding a marine radio into the shack.
I Did my research and comet gp-9nc looked like the best dual band, repeater capable, antenna... It is a commercial frequency version of comet's 2m/70cm gp9 antenna and affordable enough.
I also liked that it had the correct length (19") long radials for it's lowest frequency. Only 3 radials tho...
Upon it being delivered I noticed that the 3 radials are threaded (screwed) into a stainless steel disk at the base.
I was thinking about adding 3 more radials to the antenna, to make a total of six...
It would be easy and inexpensive. 3 stainless 1/8" diameter 19" rods, thread the ends with a 1/8 - 20 die.
Drill 3 holes in-between the 3 existing radials and thread them with a 1/8 - 20 tap.
And have 6 radials instead of 3....
I do have circulator/ isolators on the tx of both radios, band pass cavities on the rx sides and a diplexer, to keep the vhf out of the uhf and visa versa.
Any opinions, comments on adding more radials?
Please and Thank You
prcguy
I think the results of adding more ground radials will be positive and measurable. Will you see or hear any difference on air? No. BTW, I've had two commercial Comet GP-9s and while they are ok in the 460-470Mhz range for GMRS, etc, the VHF side was sharply tuned to 155MHz. I mean sharp like at 154.5MHz and below the match started to get wild and above 155.5MHz the same, so its not useable on the VHF marine band. I still have one in the garage rafters if you want one cheap.
These antennas can also have internal junctions of chrome or nickle plated parts which can introduce IMD in a full duplex system. I would recommend running a full duplex noise figure test with a load on your duplexer, then a known acceptable repeater antenna, then the Comet. If your receiver sensitivity is affected in any way using the Comet then only use it for simplex type use.
wqzw301
I did test for nickel... but not chrome. Duplex noise test sounds good thank you.
krokus
Southeastern Michigan
Is the modified disk going to handle the mechanical stress of double the physical load being attached, especially with the body being altered?
wqzw301
I did take it apart and it was an intermod disaster...... plus wire gouge brass rod.
I gutted it and I'm turning it into a broad band vhf quarter wave with a .5 inch copper tube element.
thanks
d
