Comet M-24SJ to Wouxun HT
Heyboy
South of the Red River, North of the Metromess
I have a Wouxun HT ( KG-UVD1P) and a Comet M-24SJ antenna. The way you must attach the coax to the radio is turn the radio. Is there a connector/adapter that you allow one to attach the coax to the radio without having to turn the radio? Confusing, yes, Frustrating, definitely!
LtDoc
Oklahoma
It is frustrating, isn't it? :) I don't have an answer for you. If you should happen to find a solution to that, would you please let me know too? Or get two of them and I'll take the other one off of your hands at a really ridiculously 'reduced price'??
Oh well, it was worth a shot...
- 'Doc
Heyboy
An answer?
Doc,
After much research, and a few orders, I belive I have found a solution. I ordered the following from Austion Amateur Radio Supply:
Item 1 77166 SMA-F To BNC-M Adapter
Item 2 AT7820 SMA to BNC Female Adapter
I attached Item 1 to the antenna then screwed Item 2 into the radio the connected the two together. I all goes together but I have not been able to test it yet.
This is my solution, time will tell if it works.
Regards,
Sam
LtDoc
Oklahoma
I have two adaptors, one has a short section of small coax between the SO-239 on one end and the SMA connector on the other end. The secont is an 'all in one' thingy, the '239 and SMA connectors in one 'chunk'. They both work, the 'better' of the two depends on the one using them, what they find most convenient. With the first, I detach the rubber-duck, screw on the SMA end to the HT and then the feed line to the other end of the adaptor. The 'one chunk' thingy works the same way, goes on the HT first, then the feed line is attached. I don't have to turn the HT to use an external antenna. More a matter of 'procedure' than anything. If done in the 'right' order, not turning the HT. If not done in the 'right' manner, I still end up turning the @#$ thing.
- 'Doc
(I like beer too! Whether I drink it out'a the can or from a glass just depends on circumstances, you know? Using a straw out of either container works too!)
