I live in the rf-jungle of Los Angeles, and my Whistler 1040 (long lineage to the RS Pro106) has a hard time, especially since I'm plagued by a pager on 152.360, along with a lot of other fire-breathers. My Uniden 396xt handles it better - but still no amount of antenna-juggling and attenuator settings were entirely satisfactory.
By chance I found an old Comet CH-32 "miracle baby" 1-inch duck tuned specifically for the 2m/70cm amateur bands. You can see the write up on that here:
https://forums.radioreference.com/s...-32-miracle-baby-saved-my-1040-500-106-a.html
Since it worked so well, I took a chance on it's bigger brother: the Comet SMA-3. Basically the same dual-band 2m/70cm amateur tuned duck, with 800-960 mhz rx-only resonance. Like the smaller version, resonance isn't the only important factor - NARROW TUNING is what acts like a bandpass / band-reject filter, which the Whistler (and even the Uniden) benefit from. For my Whistler, I had to use a bnc-to-sma female adapter.
Examples compared to even the canonical "RS 800 mhz duck":
** RS 800 Duck **
PAGER Firebreather on 152.360: Full strength overload
NOAA Wx: Full strength overload
** Comet CH-32 Miracle Baby **
PAGER Firebreather 152.360: GONE
NOAA Wx: GONE
** Comet SMA-3 **
Pager Firebreather 152.360: 2 bars
NOAA Wx: 2-3 bars
** ALL OTHER DUCKS including other 2m/70cm amateur dual-banders **
Similar to RS 800 Duck. That is, even though resonant on other bands like 220 or my beloved Icom airband duck, pagers and noaa just blow right through, making the front-end noisy, *especially* up at 927mhz where I do amateur repeater monitoring.
My interest in 927mhz amateur repeaters led me on this journey. It is even harder than 800mhz comms, which for the LAFD is so strong that it was hard to tell if I was making progress or not. But 927 amateur repeaters, along with it's own inherent band noise? Wow, what a pita.
No amount of antenna juggling and attenuator settings was really satisfactory from my 20 years of duck collecting. Yes, the Uniden 396xt coped much better than the Whistler - we all are aware of that. BUT NOW, with the Comet's, I am finally at the point where I can clean out my "duck drawer".
Although the front-end was tamed by the tiny CH-32 miracle-baby, and makes a great 800-960 rx-antenna on it's own, the very narrow tuning meant that I couldn't even hear out-of-band comms, which I sometimes desire to do without swapping out antennas all the time. Not convenient.
Could I find a middle-ground? YES. The longer Comet SMA-3 has the same narrow-band tuning for the 2m/70cm amateur band, but is long enough to allow for reduced sensitivity reception of out-of-band comms, but still have enough attenuation to keep the Whistler's front-end clean. I'm stoked. Note that other 2m/70cm amateur dual-band ducks may be resonant too, BUT they may not provide such tight out-of-band impedance attenuation as the Comets currently do. (at least these two models - I haven't tested the entire line.
So if you live in an rf-jungle, and are trying to cope with a Whistler / GRE / RS front-end, or even want to improve your Uniden (my 396xt showed a slight improvement too!), then having both the CH-32 and the SMA-3 in your bag to my mind, would be all you'd need.
The moral is that just because an antenna is "resonant", or is touted to be "able to receive xxxx to xxxx mhz", does NOT mean that it is narrowly tuned, where that benefits a scanner front end. A paper clip is also broadband, but it too FAILED in my situation. Only narrow-band tuning saved the day for me in the jungle.
Ok, I could do without the hinge in the middle gimmick, but I can live with it. Might be useful for other scanners that are primarily horizontal in operatin.
** RS 800 Duck **
NOAA Wx: GONE
** Comet SMA-3 **
NOAA Wx: 2-3 bars
