Commercial businesses using FRS/GMRS? Chick-fil-A, I'm looking at you.
napjerk
SA TX
Hi, I'm new here. :) Just getting that out of the way.
I'm pretty sure the Chick-fil-a restaurant 2 miles away from my house is using HTs on GMRS to relay orders etc. Isn't this improper commercial use of the band?
They seem to send one worker out to wrangle the drive-thru lines using an iPad and what looks like a cheap/Baofeng HT. They use the HT to relay large/unusual orders ("I need 6 regular sandwiches and 3 vanilla shakes", etc), and when they key up, it sounds like they're standing right behind my chair. They're probably not even using them in reduced power mode (they only need to TX like 40 feet to the kitchen) as they really blow my hair back when they transmit.
They seem to be using them simplex on 462.6375
It's not a horrible inconvenience but what would you do?
Mike
WRFW327
KK6ZTE
California
FRS is licensed by rule. This means an individual license is not required to operate an FRS radio provided you comply with the rules. You may operate an FRS radio regardless of your age, and for personal or for business use if you are not a representative of a foreign government.
Very simple google search for FRS business use. It's the featured result.
There's nothing wrong with business use of FRS as long as they're using part 95 FRS radios.
wtp
Port Charlotte FL
i listen to everyone.
it is short lived, until this virus stuff goes away.
lock out that channel or listen for any funny stuff.
i left a fast food line one night when they said between themselves, "we need the bug guy here fast".
information is always useful. i did go back at a later date, it was no big deal.
Since they are legally authorized to use the frequency, as @KK6ZTE pointed out, why would you want to do anything to interfere or otherwise affect them? If you can prove they are not using a properly certified radio (your OP says "looks like") or wrong power setting then you can file a complaint with the FCC, but good luck. And, you never said where you are when "they really blow my hair back when they transmit". Are you a mile away at home or sitting in the parking lot listening?
napjerk
SA TX
I didn't want to do anything to interfere or affect them, I was asking if it was common/accepted and if there was anything I should do.
I don't care to "report" anyone.
I may not have said it clearly but I am 2 miles away when they key up.
Hey, sorry I said anything at all. carry on.
SigIntel8600
Communications Receiver Nut
Pine Barrens
Mike
WRFW327
Some businesses have grandfathered licenses for GMRS, but most likely they are just misguided bubble packers. What are you using on receive that "blows your hair back"?
  • Like
Reactions: RRR
SigIntel8600
Pine Barrens
Chance favors the prepared, SIGINT goes a long way with staying prepared. I also listen to whatever I can.
napjerk
SA TX
Eh, it's no biggie, I usually lock that channel out when scanning anyway.
As for my receiver, I pick it up here at my home, suburban terrain, ~2sm from transmitter, I hear it thru my Radio Shack Pro-2052 / Tram 1411 on a 20ft mast. I also hear it loud and clear on my cheap chinese HT and my SDR etc.
I've driven through there before and noticed they were using what looked like baofeng (dunno, uv5, uv8) HTs which aren't Part 95 certified, IIRC.
That's the only reason I brought it up. I couldn't care less about them using it... I also pick up the Discount Tire nearby but at like half the apparent transmit power.
n1das
Nashua, NH
Mike
WRFW327
Business use of FRS is legal as others have pointed out. They are legal on FRS provided they are using the right equipment (FRS radios).
Leave them alone and let 'em be.
romanr
Cheese country
…{stuff deleted}... I also pick up the Discount Tire nearby but at like half the apparent transmit power.
Using FM, the transmit power doesn't really affect the perceived "loudness". The strength of the received signal affects the background noise more than the volume of the received audio.
With FM, it is the transmit deviation that affects the received audio volume, Ignoring background noise level, the tire store that you monitor could be transmitting at 50 watts and the fast food place may be transmitting at 1 watt. If the deviation was the same, your volume would be the same.
n1das
Nashua, NH
Business use of FRS is legal and provided they are using FRS equipment. I am all for them using radio communications if it helps them get the order right and operate more efficiently. Just get the d@mn order right!
I'm curious what the employees might be saying if they think nobody can hear them because they are using a "privacy code" LOL.
MTS2000des
5B2_BEE00 Czar
The CFA's near me all use some Midland FRS/GMRS radios and are on FRS 14. At least someone is doing some good with this radio spectrum.
The radios and there system of people placement to get folks thru the drive-thru works very well. and FWIW they've never hosed up my orders.
tweiss3
Is it time for Coffee?
Ohio
Funny enough, I went on a trip 2 hours away on Saturday, and we arrived at dinner time, so we grabbed CFA. I was tuned to the local repeater, and started hearing some of the CFA order running. They were using Midland HTs, but it sounded like complete crap. I thought maybe it was because it was FMN, so I switched to narrow band and it didn't improve. Probably because I was 7 feet away from them and the antenna was high on the roof.
Anyways, It was the first time I ever noticed.
