Commercial DMR listening?
ClemsonSCJ
I've recently gotten into DMR and have a hospital nearby that is on 2 repeater frequencies that use DMR. I can listen to it using a DMR decoder on my RTL-SDR but i'd like to be able to program the receive frequency into my Anytone 878. I'm not very knowledgeable with DMR yet but when I add a channel it wants a talk group. Would I have to know their "talk group", or can you talk on a DMR repeater without needing a talk group?
nd5y
Wichita Falls, TX
You need the color code, time slot and talkgroup ID to talk on a DMR repeater or receive only that talkgroup. Maybe other paramaters too depending on how the repeater is configured. You might need to program that channel in a receive group depending on how your radio works.
Some CCR DMR radios can be programmed to receive all talkgroups on both time slots on a particular frequency without needing to program a receive group, time slot or TGID. I'm not sure if the 878 is like that.
ClemsonSCJ
This is a commercial frequency cause receive is 461.7625 and their transmit frequency is 466.7625, which I didn't bother programming in cause I can't transmit on it anyways. Like I said, it's a hospital so I don't think they're working on Brandmeister or TGIF or anything like that so how could you figure out their talk group? color code and time slot would likely be easy to figure out.
jaspence
Michigan
My btech 6x2 has a wildcard setting that allows monitoring any talk group or color code on a frequency.. The anytone is a close relative and might have that function.
ClemsonSCJ
Now that you mention that, it may be the feature I saw advertised as “promiscuous mode”. Maybe not but I vaguely remember hearing about it.
vselic
Be shure, they don't use RAS, because in this case, the station will stay mute.
