Mcdonalds on factory shop blvd by the outlet malls. Grease fire spreading. Evac in prog. Tender 161 responding on an additional fire in Franktown. E151,M151,E154, Quint155, Division154, Batt151, and E39. Ops13.
Thanks for all those who had switched over to my scanner , At 1 point I had 10 listeners. I will try to be a little quicker in sending out the alert on the alert page in RR. My scanner streams Castle Rock PD , Douglas County Fire, Skywarn frequencies and some other good stuff. The alert tone you hear or the beeps that you hear is only on the Douglas County Fire F1 channel.This way I know when the channel is active. You can also see my tags if you use winamp.Thanks
