Commonwealth Of Massachusetts Interoperable Radio System with Proscan
davemorin40
Nahant, Ma
Hello All
So I wanted to program some of the frequencies for MA State Police that are on the new P2 system. When I try to import from ProScan using Radio Reference I only see conventional trunked frequencies in there. Do I need to program that stuff manually?
Thanks in advance!
ecps92
Taxachusetts
Hello All
Thanks in advance!
Dave, Please update your profile for a good location/qth so we can formulate a correct response as Nascar18 is indicating
davemorin40
Nahant, Ma
Thx for the response! I do realize the P2 is not rolled out for all areas. I wanted to try to import some of the P2 frequencies even if not local to me. When I import through radioreference from proscan I can't seem to see any p2 systems. Am I missing something or it needs to be done manually since it's not rolled out to all areas? Hope this makes sense...
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
As you mentioned "conventional trunked frequencies", which is contradictory, make sure you are selecting data under "County Trunk Systems" for starters. I am noticing that CoMIRS is not listed when using Essex County. However, if you use Middlesex County you will see "Commonwealth of Massachusetts Interoperable Radio System (CoMIRS)" as a selection. All of the system's sites and talkgroups will be within that section.
davemorin40
Nahant, Ma
Ahhhh that is probably the issue! I'm not in front of my computer but I believe I was trying to select them from the "state systems". I will check it out!
Thank you!
ecps92
Taxachusetts
Thank you!
for now, your Essex Sites will be best found at
Unless you are southern Essex near Revere for some of these
but you will hear very little MSP on Massport, Cambridge or the 700 overlay at this time
garys
Texas
Somewhere on my home computer, I have the various "zones" for the new system. Note that's not the correct term, but I can't recall it off the top of my head. As has been mentioned in the past the new P25 system will be much more granular than the current mostly analog system.
You'll find the information here,
nikronzo
Simulcast "Zones" or "Cells"
ecps92
Taxachusetts
Talkgroups listed
with a T are those that are P25 and could/can be P2 but are mostly P1 usage for backward compatibility.
Don't get to WORC much but reports that some of their TG's are P2
