I came across a PRO2096 with a display that doesn't work. Other than that, it's in quite good condition. I fixed the display and it seems to work fine now (disclaimer: I'm good with electronics but began this knowing nothing about scanners)
Now I'm trying to program it with a computer interface cable. Going off this schematic (http://www.starrsoft.com/software/Win96/cables/bp_pcifcablea.jpg) I built something similar. I see that the scanner expects 3.3V instead of RS232's positive and negative voltages. So that's what my circuit does. If I use Win96 and upload to scanner, I get a nice pulse train between 0 and 3.3V on the output, and feed that into the PC/IF jack using a stereo cable and connecting ground to the base ring and the signal to the middle ring.
The scanner doesn't respond. All it does is continue to say "*CLONE MODE* UP to send, Remove Cable to Exit". If I try pressing up and then 1, I see data coming from the tip connection of the plug.
Now, there's no guarantee the PC/IF connection works. This thing was basically thrown in the garbage when I got it and I assume it's because of the display which I fixed. But it's transmitting data, picks up radio transmissions, and knows when I plug a cable into PC/IF. Is there some other secret to this? Why won't it respond when I send data to it?
