Scanner: Uniden BCD396T
OS: Windows XP
Software: Uniden Avanced Scanner Director
USB to Serial cable: Tripp-Lite
Driver version: 1.3.0.0 off the Tripp-Lite CD
I got the Uniden Scanner Director software downloaded from uniden site. Got the Tripp-Lite USB to Serial adapter and its drivers installed.
When I try to communicate with the scanner, it generates this error message:
Communication Error! Please check scanner remote setting.
I tried:
Checking voltage of 2700 MaH NiMH cells, they are all at 1.29V and good.
Syncing baud rate on both the scanner and the software end. I tried almost all settings, including 9000, 38400 and others.
Syncing the COM Port on the scanner and the software. Currently using COM4. Tried COM3 and COM1. I get much farther in COM4 and COM1, it flashes Reading scanner model and then announces the dreaded Communications Error. With COM3, I am unable to get even that far, it just says - unable to connect to scanner.
Nothing else is using COM4, there is no conflict.
Turning off FIFO buffer in Settings/Control Panel/Devices/COM Ports
I troubleshot the COM4 port and Windows XP says that the device is working properly.
Any other things I can try? Different software? Newer drivers?
Please help!
OS: Windows XP
I tried:
Please help!
