Compactenna TriBand
W0RS
Nixa, MO
I have a compactenna tri-band and was hoping that someone with experience with this type of antenna can help. I do know they work best on the vehicle corners. I have a SUV so it sets rather high. The compactenna works best for me with garaging the vehicle.
I want to place the antenna on the luggage rail near the vehicle corner which the mount would be grounded to the vehicle chassis. The antenna would set a little higher of the metal roof since it resides on the luggage rail.
Before I buy the mounts for the luggage rail, I was hoping that someone with the same type of setup could provide any feedback?
K4EET
Chaplain
Severn, Maryland, USA
Here is a post from 6 years ago with a situation like yours:
K4EET
Chaplain
Here is another post of a full install of a radio system using the COMPACtenna on a roof rack. The description is near the end of the post.
kh2
There are like or leave it groups for the COMPACtenna. I like it and have 3. I am running an HT at 5w and my IC-705 on 10w. For my truck I have it in the worst possible position. Front fender mount. it works amazing. I am not advocating doing what I did - my ultimate mount will be above the 3rd brake light. But even in the poor location I cannot believe how well it performs.
Side note I have an SDS200 hooked up to a Diamond D3000N discone, on a 2nd story deck (yup I know) and a second scanner hooked up to a COMPACtenna on the corner of a cookie sheet on the 1st floor of my L/R and I hear the same on both scanners - no BS - period. Take it for what it's worth - RF is a strange beast at best. In my case it's everything wrong and it works awesome.
Your mileage may vary
prcguy
Most antennas including the COMPACtenna will loose radiation efficiency if mounted several inches above a ground plane like on a roof rack. It may improve the SWR on VHF compared to the middle of the roof due to the way these antennas work but it introduces problems. If there is a way to attach a moderate size sheet metal ground plane to the roof rack like in a corner where you have bars that meet it should improve performance without creating too much of a ground plane and causing SWR issues. Using the picture example in post # 2, maybe a triangular piece 1ft X 1ft on the edges mounted in the corner with the antenna stuck between the front bar and the one several inches behind. You could even Ty-Rap a triangular sheet of metal in the corner of a roof rack with the COMPACtenna in the middle.
