Apologies if this has been answered elsewhere but I've not been able to find any good references to my specific need (700/800 MHz) when it comes to PL/259.
As it stands today I've got a 770 MHz Yagi and a 2M/440 J-Pole set up in my attic. They feed a Comet Duplexer. I'm using the Yagi because the system I primarily monitor is running simulcast and my house is in a bad spot to monitor the system with a normal antenna. At the time of the installation I cobbled together the connectors I had on hand. LMR 400 runs through the attic to the office wall where it terminates in a PL259 bulkhead. On the other side I've got a PL259 right angle adapter feeding the LMR 200 scanner coax which has 259 on the one end and connects to the scanner with BNC.
Honestly things are working well enough right now but I would like to try to pick up an 800 MHz system that is pretty much in line with my Yagi's current orientation. I realize that the bandwidth isn't ideal but the real trouble is the distance. At times I can copy it and at other times the signal is just barely adaquate so there is a lot of distortion.
With all of that said, here's what I'm wondering, how much signal loss could I eliminate at the 800 MHz band if I reduced several connectors from:
PL/259 -> Bulkhead -> PL/259 right angle adapter -> PL/259 Plug -> BNC -> scanner
to
N -> Bulkhead* -> BNC -> scanner
* Pasternack makes an N to BNC bulkhead that would probably suit my needs.
For what it's worth the antenna side of the attic line is already N so I don't plan to change that.
Thanks for any insight you can offer!
to
