Computer isn't recognizing my RIB?
Mikem001
I'm using cps R06.12.05 and I'm trying to program a cdm1250 thru a remote head. I purchased an aftermarket rib and cable on eBay and when I open cps and try to read the radio I get the can't open port error. I tried both com1 and 3 in the cps and get the same error, Is there some settings on the computer that I need to switch other than that, because I don't see it come up in the device manager or anything. (Btw I'm using an old laptop that is running Windows xp and had a real serial port built in)
cabletech
Puget Sound
1) What cable setup are you using? USB or the older serial port RIB with cable?
2) The newest software version is 6.12.09.
If using USB, do you have driver loaded? Go to device manager and see what port is assigned. Some times the program will not see com port 5 and above.
Mikem001
1) I'm using older serial port with rib
2) I know what the latest version is how ever I don't have access to it and didn't have a problem with the version I currently have before this
cmdrwill
So Cali
Some RIB do not work well with some computer serial ports. A known problem.
The RIB design (design that is a joke) does not follow the RS232 Serial Port Standards.
Even the Original Motorola RIB have problems, piss poor design.
Mikem001
I just want to clarify something are there people out there that have had success using an aftermarket RIB or its guaranteed to be a waste of time?
Mikem001
I ended up buying a usb to serial cable at radio shack for $20 and it worked perfectly with the aftermarket RIB without any errors. It goes to show not always is the built in serial ports better.
Nasby
Ohio
I've had 100% success with aftermarket RIB's and cables.
I use them on my older Jedi and Saber radios.
They have all come from KAWA Mall.
N4KVE
PALM BEACH, FLORIDA
I use a "Radio Stew" rib with much success. But most of my older radios work fine with "ribless cables" plugged into a serial port.
Skypilot007
Medford, NJ
To simplify your setup you could have purchased the serial ribless cable for the CDM series from KAWA mall. These work great on my remote head CDM's. Never had problem with it. Some folks have issues programming through the remote head but I have never had and problems using the cable I mentioned.
jaspence
Michigan
1250 cable
I have had very good luck using a ribless com port cable. KaWaMall brand works well.
