Computer Monitor Noise
trimmerj
Pasadena, MD
My 17' crt monitor generates a lot of hash in the lowband vhf range. Would a LCD generate less noise ?
n3bxv
Severn, MD
My LCD also generated a lot of noise until I played with the refresh rate and found one that didn't seem to produce as much noise.
brandon
SoCal
I've had 2 different ViewSonic LCD monitors near the radios and none of them made noise.
Routers have been my biggest noise culprit. Only solution was to move it far away and have everything on wireless.
Dorpmuller
Central Pa.
My issue is not my CRT monitor-that's fine-but my POS Speedtouch DSL modem spits out so much sh*t that it makes the radios useless.
Rich
R
Rayjk110
Guest
My terayon router for where the ISP enters my house is in my personal server rack, and it still generates noise. If I go to my basement radio desk by my server rack, I can forget about Apco25 digital on my XTS3k/5k, or the digital scanners. Just seperate the router from the radio.
I actually moved one of my repeaters from the basement to the attic because of so much crap from the router, and this was with heliax coax, too.
Luis_C
Hermosillo, Sonora, México
Same here, isn't that bad now, thought LCD never that bad like CRT, I was scanning at about 2 meters of the CRT monitor of a friend, and the scanner was unusable. I wonder what component of the LCD causes the noise.
My router creates a lot of noise even if wireless is disabled. :(
Napalm
Calls provider
Lake Co, Ind
My LCD has recently given me a load of noise around 280MHz. Switch the monitor off, the noise goes.
Then again the scanner was directly under the monitor :)
