Hi guys,
"If I remember right (and I think I do) it is the green wire to any of the black wires. Some times you also need to jump the grey wire to a ground."
FFFZZZAAAPPP!!!
Rule of thumb, when in doubt, don't. Even if you get it to switch on you still have multivoltage outputs to consider, uh, 12V+ is the red and black, uh, negative, I think. Actually that output hasn't much "oomph" since it's meant only to power a fan or two, a 500W supply may put out only 1W at 12V, the rest being for memory and logic.
The best bet is ask yourself why the power supply in the first place and do I really need one? If after much deliberation the answer is "yes" then go for a regulated supply with sufficient amps output to power everything comfortably, then double the amps. Why? So the supply doesn't strain, that's why. I have a 60A supply running 3 ham rigs and still I only transmit one at a time and eventually it gets rather hot. The average 18 year old kid can carry a 100lb sack but a strong man can go the distance with it.
