That is correct that Cabarrus no longer maintains a watch on the inbound side of the VHF dispatch frequency. About 5 years ago the only site in the simulcast that had a receiver active was at Mt Pleasant to allow for West Stanly units to talk to Cabarrus if they didn't have an 800 radio, but that was to be shut down around the time the county went P25 is my understanding. Now that Stanly is primary on 800 along with all the other surrounding counties it is less necessary based on Marshall's reasons above. Not to mention less interference and potential for anyone with a cheap analog radio to harass dispatch or gain access to a trunked system.
Kannapolis does monitor their VHF frequency still and a large percentage of the radio fleet is dual band APX7000 with Kannapolis fire, Rowan fire, and other VHF tac frequencies for use in case of a system failure.
Marshall, take a look at NFPA 1221 for "Standard for the Installation, Maintenance, and Use of Emergency Services Communications Systems". A quick Google will produce a million firehouse forums and articles that touch on the key points. Having a secondary means of dispatch and a "hardened" means of primary dispatch (by NFPA standards) will count towards a better ISO rating.
