Condensing Talkgroups
samcken
SE Connecticut
I would like to transfer the CSP trunked system to one playlist. It is currently spread across several. Can I do this with one command somewhere, or do I have to transfer the talk groups one by one? I'm using the supplied 668 software. Thanks!
N8IAA
Fortunately, GA
I have a PSR-800, and do that with multiple Scan Lists. You need to go into the software and click on trunk systems. click on the system, then click on TGID's. Then just click on the ID's and switch them to the separate Play Lists.
HTH,
Larry
