condo which antenna ?
usnasa
Brooklyn NY
hello all
I have a question I am currently living in brooklyn in a ground floor condo which doesnt allow outdoor antennas I am using a pro 2055 scanner with the stock antenna I would like to use maybe a mag mount antenna there is a window near my desk my question can i use any mag mount CB antenna with the bnc connector and if not which one would you recommend thats better than my stock antenna. I would like to listen to some frequiences in the 800 range and some aircraft ch's any help would be very greatful
thank you
lanbergld
Richmond VA
Hello, here's my tip: I'm an SWL and VHF/UHF monitoring hobbyist. I live in a high-rise. So I never use outdoor antennas. The best indoor antenna for VHF/UHF that I've ever used (and still currently use) is Ebay item # 270279073598. (Copy, paste that number into Ebay search engine.)
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
usnasa
Brooklyn NY
thank you very much that looks nice but i am on the ground floor near a window does it have to be near a window ? or just stand it up and does it really work thanks
lanbergld
Richmond VA
Hi, yes you're right indoor location can be an important variable. I use my indoor antennas right on a window. Yet -- they do work better than stock whip antennas when NOT on a window. But they seem to be their strongest right on the window. The reason I led you to that particular antenna is because I use many different ones & experiment with making my own. That one -- the one in the ad -- does very well an ALL of the VHF/UHF bands. (Others just do well on 2 meters, others are better around 160 MHz, etc.)
Try it out. I have a ton a various indoor antennas rigs -- the one in that ad is definitely top-notch for the entire range of 118 MHz - 900 MHz or so.
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
lanbergld
Richmond VA
You're very welcome. That's how I found out which antennas work best -- by giving different ones a try! Many folks will say things like, "If you live in a condo or apartment you have my sympathy", but believe me I get all over the world using simple indoor antennas. On shortwave I can easily listen to airports over in Europe. I know people with large outdoor dipoles that can't do that unless conditions are just right. Just have to experiment a lot.
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
blueangel-eric
Emporia, KS
How does that antenna work? Is it just a 300ohm tv wire jpole inside that pipe or what? How broad banded is it?
Eric Burris
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
k9rzz
Milwaukee, WI
Hey! It says on the Ebay description that it will even work with my Philco scanner from 1947 !!
Whoooot !!
lanbergld
Richmond VA
Hi, Well I haven't opened-up that particular tube J-pole, but I have have bought & used several of his other antennas. Typically, on non-J-pole PVC tube antennas he sells, 22 AWG copper wire is helically wound round a long wooden dowel rod inside. But again, I don't want to bust this particular J-pole by opening it up. (You'd have to break it...he makes these things rock solid & very well-soldered). I'll try to answer your question by telling you the following:
I have several other models of his. He sells a 24" J-pole that, on my radio, really really REALLY peaks the 800 MHz transmissions. But that one isn't the best for, say, VHF Aircraft or even 2-meters.
He also sells a Brass Slinky that I myself hard-wired into a banana plug, which I insert into a UHF-BNC adapter & right into the back of the scanner. Now, that one really rules on VHF Aircraft & down to Citizens Band. I'm talking a 2x increase on my S-meter (which the AR-2002 has) over other external scanner antennas. But it will not be best for, say, > 400 MHz.
Long story short, the 30" J-pole I recommended to the other viewer has done me extremely well on ALL of the bands from 118 Mhz - 900 MHz. I don't have to 'switch' antennas, in other words, when I jump to different bands.
I've used a lot of expensive (> $100) antennas in the past. I can attest that this man's handbuilt antennas are actually better those -- once a person learns which models are best on what particular bands. Experimentation is the key, and is what makes the radio hobby dynamic. Those antennas I mention, although inexpensive, are extremely well-built. They might look like toys or something but they are not. One time I tried attaching one to the outside of my window. It fell 12-stories down to the concrete. I went down & found it -- in the very same condition as before it fell all those flights!
That's the best way I can answer the question & I hope I answered it well enough.
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
Stretch5
Larry Lanberg
Richmond VA
AOR AR-2002
Palstar R30C
I am a novice.....will this antenna work with this scanner ?
http://www.rfwiz.com/Scanner/UnidenBearcat_BC120XLT.htm
