The Edit \ Add Channels On Range dialog ignores manual location data entry, and always uses the scanner's location the last time you read from the scanner. If your scanner location is set somewhere in Nebraska, the favorites list always gets populated with Nebraska data, even if you manually enter a California ZIP code or GPS coordinates in the dialog.
The only way to get California data to populate the favorites list is to enter a California location in the scanner, read data from the scanner in Sentinel, then run Add Channels On Range.
Also, the menu label "Add Channels On Range" is incorrect Engrish. it should be "Add Channels In Range", or better yet, "Add Channels Near Location".
