Confused about digital and conventional
vc3fam
Scranton, PA
I am not new to scanning, been programming scanners for years. However, I can't grasp this digital age. Can someone to me the range to which digital operates and how to program these frequencies into my scanner? I have a Uniden BCT15X. I have searched and searched and can't find any answers or maybe they were staring right back at me because I don't know what I'm looking for.
Buttabean
Georgia
Im not new to it either but since 1994 when i owned my 1st scanner the radio waves have changed dramatically! If this is your scanner here--> Mobile BearTracker™ Scanner with 9,000 Channels and GPS Support - Scanners at Uniden Its not gonna receive digital signals as it is only a analog reception type scanner. The digital scanners start around $499.99 and go up from there. Digital Mobile Scanner with 25,000 Channels and GPS Support - Scanners at Uniden And with all the new encryption thats being installed on P25 Digital Radio Systems you most likely wont hear police channels broadcasted to where u can understand/decode their signals. I didnt see a response on this post & thought i'd throw it in.
mass-man
trying to retire...
Parker Co., TX
Your BC15X won't receive the digital modulation on any frequency. It is still FM, but a digital voice signal on that channel. P25 is the most common you will see and a certain scanner will receive P25 phase II. You could program all the channels you want, to no avail. As well, many users of digital modulation are also on trunked systems. These you can hear, but only if they use analog modulation.
Digital scanners do start at $500! But it will be the only way to monitor services that go digital in your area...
xxdanielt3
PA
Take a look at the Radioshack Pro-197 as mentioned. Other options that might be a little bit lighter on the wallet are a used Pro-96 or a Pro-106. You could also check out GRE scanners. The only scanner that can recieve P25 Phase II is a GRE-800 and possibly the GRE-900 when it is approved by the FCC.
Also check out the Uniden line of digital scanners. Check your local CL to see if anyone has a second hand one you can use. Ebay is also another option but it could be sketchy not seeing the scanner first hand.
Common digital scanners:
BCD396T - The RadioReference Wiki
BCD996XT - The RadioReference Wiki
PSR-600 - The RadioReference Wiki
PSR-500 - The RadioReference Wiki
Pro-2096 - The RadioReference Wiki
Pro-106 - The RadioReference Wiki
Pro-96 - The RadioReference Wiki
http://wiki.radioreference.com/index.php/Pro-197
Comparison chart:
Digital Scanner Comparison Chart - The RadioReference Wiki
n5ims
Digital signals operate on the same frequency ranges that normal analog signals do, they just use a different way to encode and modulate the signals. It's quite likely that an agency that operates on 154.980 MHz using a plain old analog signal finds a few bucks in the bank (well, quite a few) or qualifies for a grant and desides to go out and buy brand new radios. Their old frequencies happen to work fine for them coverage wise and they don't want to add any unnecessary expense for new antennas, tower crews, etc. and just upgrade their old frequency from analog to digital.
Let's say that they get a grant that has a qualification that it must be used for radios that use the P-25 standard (what we call a standard digital system). They buy a brand new repeater, new mobiles, new handhelds, and even new base station radios (it was a really nice grant!). They get their communications consultant to modify their existing license to add the necessary emission code(s) for legal P-25 operation on their old 154.980 MHz frequency. Once the new equipment is installed, folks are trained on how to use it they're ready to go. Finally the day is there for the switch-over and everyone turns off their old radios, turns on their new ones and poof they're now digital!
At that point, all the scanner listeners are mad because their old scanner won't work. Some folks are saying that they're now fully encrypted (possible, but not likely) and give up the hobby. Others plunk down the $500 or so for a new digital scanner, program in that 154.980 MHz as a standard P-25 channel and continue to enjoy their hobby as if nothing happened. Hopefully somebody will submit a change to RadioReference.com so the database can be updated to signal their transition from analog to P-25 digital on 154.980 MHz so others can easily know about the changes!
Sorry, but you're one of those folks that will need a new scanner since yours won't handle digital signals. Be sure to check the database to veryfy that your folks moved to the P-25 standard and not one of the other digital modes scanners don't currently work on (MotoTRBO for example) or even have actually added encryption to their signals.
fredva
Virginia/West Virginia
You can find used digital scanners in good working condition on ebay for less than $300 if you can't afford a new one. Determine what type of systems you have in your area, and pick a model or models that will work on those systems. Not every digital system is the same. For example, some use 700 mhz frequencies, which only the very latest scanners will receive.
