Confused About How To Figure Out LCNs
natedawg1604
Colorado
So, if a Cap+ site has different color codes on different frequencies, does it make any difference to radio users? Is this done intentionally to force certain radios to always use certain frequencies or something? Or, do color codes make no difference on Cap+ systems?
Voyager
Is it possible that a system can skip LCNs and just have no frequency? Like, can you have 1 system with a 3/4 frequency and a 5/6 frequency, but no 1/2 frequency?
Yes. I've seen one system that had interference issues, so they just disable that TX or put it on the lowest priority (it only gets used if no other slots are available).
Voyager
It makes no difference to the radios whatsoever. Each frequency is programmed with a color code. The radio only cares that it matches the transmitter, and not what code it is.
CanesFan95
FL
Can 1 Cap+ system have each frequency be a different site number? Fast lane shows the site number. Most of them show Site 1. But a couple show Site 2 or 3. So I'm wondering if I'm safe to assume that all repeaters on the same system have to have the same site number.
natedawg1604
Colorado
Actually I noticed the exact same thing recently. It appears the event log in 2.10 automatically displays Site#=1 for all non-linked Cap+ systems by default, even though the terminal output does not show any site#, which suggests there is no actual site# being broadcast in the CSBK messages. Regardless, I'm guessing they did this to have a placeholder field for monitoring Linked Cap+ systems. However, as a result it appears that in order to monitor a non-linked Cap+ system in cc trunk following mode, you must specify a dummy site# of 1 in the frequency file. Does that all sound correct?
CanesFan95
FL
I've seen a couple Cap+ frequencies that don't display any site number, but it's rare.
CanesFan95
FL
Sometimes Cap+ frequencies send their callsign in Morse Code. If there was a way to decode the callsign, that might help piecing systems together.
slicerwizard
Toronto, Ontario
Makes sense to me. I use the Cap+ site number that DSD+ displays at the bottom of the event log window for all .frequency file entries.
