Confused!!!
cj5
California
If anyone can clear this up for me, it would be great. When listening to Carroll Cty. Sherrif in NH, I infrequently get this low-tone buzzer sound (similar this http://www.kb9ukd.com/digital/motorola1.wav) right before the digital voice comes over. Now they are on the frequency 154.860, which is not in the typical 800-900 MHz range of Motorola Type 1 systems. Is this possible? Can they run a Motorola Type 1 system in that frequency, or am I just getting garbled digital noise before the APCO-25 scanner card kicks in on my BC-796D? I try doing some trunk searching in that lowere frequency range, but no ID's or anything else comes up on the screen. Gotta luv being a newb!
Regards, CJ
DaveH
Ottawa, Ont.
Moto VHF/UHF trunked systems are by definition Type II only, so that sound must be something else. Is this known to be trunked, or is it P25 conventional? That might explain the lack of IDs. What exactly is the "lower range"?
Dave
cj5
California
Lower range
According to this website, http://www.kb9ukd.com/digital/, there is the "Motorola Type 1 (old) Trunking Control Channel", and the BC796D manual has a programming section for Type 1 systems (see pg. 47). This is what got me going in circles. I am aware of the fact that most systems are Type 2, and operate in the 800-900 MHz, range (opposite of the "lower range", 153-156 MHz). Up here in NH, public safety mostly, if not all, operates in this "lower range", which is why I first thought they didn't use trunked systems at all. But what also got me curious was, for example, in a typical dispatch-mobile conversation, I either get all dispatch, or all mobile, and rarely get a two-way or more conversation. The reception is genarally clear, especially since it is digital, and never broken, thus it's not a matter of bad reception. So I'm curious to know if maybe they are using an older trunking system, and if that's not the case, what in the world is that game-show buzzer sound preceding the transmission?
mdulrich
Van Wert, Ohio
According to the RR Database, this isn't a trunked system. The buzz you are hearing is probably the scanner syncing up the digital signal to decode it.
Mike
cj5
California
Thank you
Thanks, that's the answer I needed. If you're sure. I mean, how does RR determine that a frequency is trunked or not? Is it based on user input, or is it based on some kind of FCC query?
