hvytrucker
HvyTrucker
Check here on RR database under Illinois under Randolph County, seems like it covers Chester Il also... When using Sentinal and you find a system department or channel you want to monitor you can add just that one to what every favorite list you create. All you have to do is find what you want to listen to then highlight it and click the "Insert" key on your keyboard or right click on it and click "Append to favrites list" and that will save it to a favorite's list of which you already have or you can create a new one. Then you have to go into the "Service Types" section and make sure you check which service types you want to monitor... Once you do that then youhave to check in the "SCan Selection" section to make sure that the favoites that you have are checked "Monitored" & "Download" otherwise it won't load them at startup.I have tried to put channels in my 536 scanners I have read all kinds. Can some one please help me !!!!
I think that should get you started but please if there is anything of my instructions are wrong, anyone who knows better please correct me...
Hope this helps you.
