Connect Plus LCNs necessary for scanner?
NM9X
Mt. Zion, IL
Can I successfully follow Connect Plus trunked TGID conversations by control channel only monitoring? If not, is correct LCN order necessary for this system? Using a TRX1.
Ubbe
Stockholm, Sweden
TRX scanners doesn't do control channel monitoring in DMR trunk. It scans all frequencies you have entered in a system for the talkgroup and there's no need for LCN. When an active user releases his PTT the TRX scanner immediatly scans all frequencies in the system for that TG during the delay period.
/Ubbe
Forts
Ontario, Canada
You need all the system frequencies entered. Control channel only doesn't apply to Connect Plus, EDACS, etc... just P25.
