I just came across a review for this radio.. I guess I missed the announcement because the review was posted last month... (I searched RadioReference and wasn't able to find anything on it.. But I've been wrong before
It seems impressive for a cheapie handheld. It has some cool scanning functions.
Link to Connect Systems site: Connect Systems
A review from the link below:
https://hamgear.wordpress.com/2016/...24/review-connect-systems-cs-580-dmr-tier-ii/
– Enhanced Monitor – Simply put, I enter the repeater's frequency and the radio monitors everything that comes across, regardless of Time Slot. If I hear a station I like, I press the Lock button, and I’m ready to transmit. The DMR ID, CC, Slot, Type, Contact #, Tx and Rx frequencies are displayed on the LCD.
– Group Receive – This function allows you to load up to 16 contacts into a single receive group. If any one of those channels becomes active, that’s what comes through the receiver. When transmitting, the pre-assigned transmit contact for that channel is the one selected.
– Enhanced Scanning – This allows you to select a scanning range between 400-480MHz, repeater offset, and channel spacing. When a repeater signal is detected, the scanning stops, and there is an option to Lock onto the frequency. When keying the transmitter, the offset will automatically shift the frequency to the desired shift.
– Standard Scanning – This is when you add channels to a scan group. If you are listening to a TG or channel that is part of the group and select Scan, the radio will now scan all other TG or channels within that group.
– Enhanced Parameters – This is field programming made easy. It allowed me to program everything via the keypad. In the DMR mode, I entered the CC, Slot, Type, Contact #, Tx Freq, and Rx Freq. A quick press of the Lock key, and I was on the air.
In the FM mode, I entered the CTCSS Decode and Encode, Tx and Rx Freq. Once again, press the Lock key and it was on t
