Connect tone
OCO
Central Michigan
If you have a scanner you don't need it and no scanner displays it.
The CT is used for programming radios to transmit and function on the system, which is something you shouldn't be doing... :)
Mtnbiker:
Can you be more specific on what scanners directly use Connect Tone info, or actually display it. SInce my error last night, I'd read quite a bit more about the use of CT's and thought I had an understanding of why a scanner wouldn't need it..... Not challenging, just trying to understand...
Not the first time this has come up..
trumpetman
Charlotte, NC
Your Pro106's display of "CT" is GRE's abbreviation for CTCSS, not Connect Tone. The difference is defined earlier in this thread.. (Hey, gain a little knowledge, share it....) <grin>
I'm more than familiar with the difference...but I'm looking at my scanner right now that's showing a CT: 138.46 Hz (NOT a standard CTCSS tone, but in fact a connect tone) for the statewide system. And the local public safety system is 116.13 Hz, also not a standard CTCSS tone.
Although they serve similar purposes, they are two different things with two separate standard values.
trumpetman
Charlotte, NC
Mtnbiker:
Just to chime in, scanners don't NEED/USE a Connect Tone like a professional two-way would need. It does however assist in us hobbyists to tracking systems. If I come across a conventional 800 MHz frequency with a PL tone of 91.5...then there's a good chance that's using a connect tone of 90.00 Hz on a trunked system. In a dense area of trunked systems, this makes it easier to narrow down what frequency belongs to what system, especially when you're out and about without internet and only have your own database to work off of.
From what I've read, the basic concept of a connect tone is similar to that of a CTCSS tone used in conventional systems, although not that simple.
Gain some knowledge and share it right? :D
OCO
Central Michigan
Here's what I found last night that describes the function of Control Tone in the overall trunking protocol chain. (written by some guy named Wayne a few years ago).
As afar as the relationship between the CTCSS frequency and the CT's, I've seen at least one thread about CTs in which Slicerwizard didn't think so.
The thing that I've learned is that the Control Tone question comes up almost as often as "streaming good/bad". Too bad I didn't pay more attention a few years ago when I occupied office space with the MPSCS engineers...:D
MtnBiker2005
San Diego County, California
Read what ecps92 said on page 1 on this thread.
If you're searching say 850-869 band. You might run across a freq with a NAC Code. You would know it belongs to one trunked system after you match it with [SystemID & Connect Tone]. but still have to narrow it down to the site it's coming from.
Like if you search 380-390 and come across NAC140. You would know it belongs to a 14C system site somewhere!
WayneH
Forums Veteran
Super Moderator
Your master site
That would be me.
It's nice to have in the database more for reference purposes. Sometimes systems propagate far enough that it's possible you could run in to two licensees using the same freq and it being Moto trunked. Using different connect tones will keep audio from being passed similar to how a PL in conventional use.
When you program in the incorrect CT for a system and initiate a TG call you get a channel assigned to you but when you switch to the voice channel the system sees the wrong CT and drops the channel after a specified time. Not exactly a full-proof way of staying off a system if one wants to illegitimately program in a trunked system but some may see it as helping.
And the GRE's will display the CT when you park on the CC in tune or whatever mode supports CC decode.
OCO
Central Michigan
Well, I guess another RR user (me) has been educated on the CT subject. I thought for a layman I at least half understood the trunking protocol - guess again!
Wayne - interesting old website.. Like the Long Lines history stuff - brought back memories (4 lines to NCIC down at 3:00 AM....... oh crap!.)
ecps92
Taxachusetts
And yes, some Scanner Manuf. used CT for PL/DPL/CTCSS
Too many Acronyms.
NCIC is down ? Not here, Phew :cool:
NICS - Up
NLETS - Up
NCIC - Up
:roll:
nwassist
Banned
Waaaaaay Out there!
Wirelessly posted (BlackBerry8530/5.0.0.1030 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/104)
Thank you everyone for their input and great education!
jets1961
actually the 106 does dispaly connect tone.
The Pro 106 does display the connect tone just like trunker does.
Why do people assume the guy has bad intent if he asked a question
Way to many internet police wannabee`s in this site.
OCO
Central Michigan
If you've read the entire thread, the PRO106 's abilities were already confirmed and other questions were answered, all quite amicably and to the apparent satisfaction of the OP. Since you didn't participate at the time two weeks ago, what's your point now?:roll:
ecps92
Taxachusetts
SHHHHH, invoke your rights, the Police Commissioner is lurking :roll:
