BCD325P2/BCD996P2: Connecticut state police
ffej3580
CT
Hi I"m using freescan. trying to set up a trunking program. says
System Type:Motorola Type II SmartZone
System Voice:APCO-25 Common Air Interface Exclusive
Owners manual states that this should be programmed as a P25 system. can't seem to figure it out. I have attached my freescan file, Maybe one of you can see what i am doing wrong thanks.
  • BCD996P2 1-25-2020.zip
LD723
Ct state police is not on that type II smartzone system anymore they are on a true P25 system now. Connecticut Land Mobile Radio Network (CLMRN) Trunking System, Statewide, Connecticut - Scanner Frequencies
ffej3580
CT
does that mean this is something that is unavailable to me or am i just programming it wrong?
hiegtx
Dallas, TX
FreeSCAN is importing it as Mot Type II/P25, which is what would have been used on the older 396T & 996T scanners.
79582
Instead, use P25 Standard, Digital XT, which went into effect with the XT models of the 396 & 996 scanners. This also applies to the P2 series such as your 996P2 as well as the 325P2.
79584
On your file, I see that while you have imported the groups, with the TGIDs (talkgroups), you did not include any of the sites, You need to import the sites in your area as well as the talkgroups.
ffej3580
CT
Thank you for your help. i changed it to P25 and all is well. Thanks again!!!!
Do you suggest installing the software update to this scanner at this time? Mine is running version 1.06.00 at this time.
ffej3580
CT
thanks for your help.
Jeff.
I'm getting an error uploading to scanner with FreeSCAN saying "UNABLE TO SET APCO BAND PLAN" on a couple if of sites in a P25 trunked system. any Ideas?
