Has anyone in CT with an SDS 100 updated to the new firmware? If so what are your thoughts? After looking through the Uniden forum not sure weather I should upgrade or wait.
I updated the firmware & I actually noticed a slight improvement on analog conventional channels sounding a bit stronger but more or less everything else runs the sameHas anyone in CT with an SDS 100 updated to the new firmware? If so what are your thoughts? After looking through the Uniden forum not sure weather I should upgrade or wait.
Yes, I think it is worth it.So the updated firmware is worth installing?
Agree -Yes, I think it is worth it.
I am with you on this update. I think I will wait another few weeks if not a monthI personally will not update yet, waiting to see results from other people using the update.
Me too. I feel no rush to jump in.I am with you on this update. I think I will wait another few weeks if not a month
I like it when others test the products and software firstMe too. I feel no rush to jump in.
As with computers, phones, etc I am wary of updates that could cause issues. It's happened before with other devices.
I've done upgrade and works just fine.I updated the firmware & I actually noticed a slight improvement on analog conventional channels sounding a bit stronger but more or less everything else runs the same
Current firmware should be stored on your computer. My computer has it archived at C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater. Before you do anything else copy the firmware file and add it to a different folder so you still have it when Sentinel overwrites the stored firmware file in the Updater folder.Thanks guys. I see that Uniden had released several updates after my original post. Maybe they got all the bugs out. Still skeptical on updating though. is there a way to pull the current firm ware version out of the scanner before upgrading just in case I need to change it back?
I have everything up to C:\ProgramData\Uniden\BCDx36HP_Sentinel\. Nothing that says updater. I even searched for it.Current firmware should be stored on your computer. My computer has it archived at C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater. Before you do anything else copy the firmware file and add it to a different folder so you still have it when Sentinel overwrites the stored firmware file in the Updater folder.
Main version 1.21.00 sub 1.02.01OK, what firmware version do you need to archive?
