Put another way, you should not transmit on an antenna also connected to your scanners.
It needs to be a separate antenna with some distance/elevation between them.
On my truck the 100w ham radio antenna is about 4 feet from the scanner antenna.
At home my 100w amateur antenna is 40 feet from the discone my scanners and other receivers share. All receivers are connected to one of these.
Multicouplers which is in turn connected to the discone.
My 160 foot 1500w OCF high frequency antenna is about 20 feet above and 10 feet away from the discone mentioned above.
