I use that same eBay 365pf variable cap on my home made ferrite antenna, its a good capacitor for resonating an AM BCB loop. If you look at the second video in my links, at one point the guy is measuring the inductance of some ferrite antennas on an LCR meter. For AM BCB use the loop or coil inductance needs to be in the 249 to 250 microhenry (uH) range for a 365pf variable cap to cover about 530 to 1600KHz range.
If you made a random size loop and don't know the inductance you will have to either measure the inductance and change the length of wire in the loop or connect it to a receiver and map out where the loop peaks in frequency using the 365pf variable cap. It should peak near 530-540KHz at maximum capacitance and at or above 1600KHz at minimum capacitance. If you have an SDR receiver with spectral display the display will show the peak resonant point as you tune around and you can shorten or lengthen the wire to hit the target range of 530KHz with 365pf of capacitance across or in parallel with the loop coil.
Thank you again for the response, prcguy. I have terrible internet service out in the sticks. 144p video quality--barely--works, besides the fact that it is too blurry to see any detail. I do not own any an oscilloscope or an LCR meter. The radio I have it reads: tune, when the receiver thinks it's tuned in.
I was able to gather some things from the end of his part 2 video as well as some questions:
10-365 pf variable tuning capacitor is needed
It's put together with 1/2" cpvc pipe and fittings
1/2" cpvc slip cap fitting -is this where he winds the outer visible coil of 4-5 turns?
Would the two wires from this coil then go to the antenna jack?
45 turns of #24 wire around a ferrite rod, yet he says that he uses two 10X200mm non permeability 400 rods on the powerpoint. Does he somehow glue the rods together and place the coil onto the glued rod?
Does anyone know if he has the powerpoint or pdf that can answer these questions?
It looks like a great design, but maybe I missed the part in the video where he gives an explanation. Thank you again for your help.
