Connecting mic to rear ACC plug on control head
johndjmix
So, im trying to connect the kenwood mic to the REAR of the control head. That 12 pin "ACC" connector. Reason im doing this is since in my vehicles the radio is mounted up above the driver I dont want a mic cable dangling down.
Previously i have done this by cutting and extending the stock mic cable just after the propertiary tk-790 connector and extended it down. Sloppy...i want to do it so nothing it plugged in in the front this time.
So, here's what I got.
12 pin ACC connector on the rear of the control head:
Pin 6 and pin 3 go to the PTT on the mic.
Pin 4 and 5 go to the MIC on the mic.
Program aux input 1 to activate the PTT.
The PTT works fine, i press the mic and it transmits...but there is nothing transmitted...like the mic isnt hooked up.
FYI, the "Mute Mic with External PTT" is NOT checked.
Am I missing something here?
--John
johndjmix
ramal121: Figured it was something like that...thank you! Ill try that, i know i saw a pin on the ACC that gives 12v when the radio is on.
--John
--John
johndjmix
Got it working. Turns out it was multiple things, including a coiled mic cable that had a bad rj45 crimp on one end.
Pretty happy I got this all going, now its all RJ45 based which makes replacing mic cables simple and, should one go bad in the middle of no where, any old ethernet cable can be used.
Thanks guys,
--John
