SDS100/SDS200: Connecting SDS100 to Unitrunker software
kc4wsd
Rockingham County, NC
This may not be the right place for this question, but here goes . . .
I'm familiar with using Unitrunker with a GRE scanner, but need some guidance on the mechanics of how to connect the SDS100 to the Unitrunker software.
Can I use the USB programming interface cable? What settings should be used in the software?
Thanks in advance
nessnet
What month is it?
I don't know anything about Unitrunker, but ProScan is what you need for a 100 (200).
kc4wsd
Thanks @nessnet
I already have Unitrunker and I'm familiar with it.
I may have to break down and get ProScan, but for now I'm holding out for someone who is using (or has used) the '100 with Unitrunker.
David
KK4JUG
GA
Am I missing something? Sentinel is available free and is designed for use with the SDS scanners.
kc4wsd
@KK4JUG thanks also to you for the reply. I also have Sentinel, and that's what I use to program the SDS100. I was just asking if someone was familiar with the Unitrunker/SDS100 combination.
David
u2brent
OAMPT
KRWDPAXKRS1
I don't recall, but could be mistaken, that the SDS100 has any discriminator audio out option, Which is what you'd need to properly do any PC software decoding. (Even though there's an sdr in there)
hiegtx
Dallas, TX
brent, you are correct.
There is no option in the menu for the SDS series scanners nor the x36HP series to initiate any control channel data output. Perhaps, for the SDS series, the extra micro-USB ports might have eventually been configured to provide that. I know that the late UPMan hinted broadly that those ports had a 'future use', but after his passing, nothing has been announced. Unfortunately, only Uniden could answer the question as to the intended (future) use of those ports, and whether that project was discontinued after Paul's untimely passing.
The 'Set C-CH Output' does exist on both the XT & P2 series scanners, and for those with the Extreme Upgrade, the HP-1 & HP-2 have an option for "Raw Data Output".
GTR8000
NY/NJ Database Guy
BEE00
Why tie up a $650 scanner when you can accomplish exactly the same with a $30 RTL dongle? :unsure:
But no, the SDS series will not work with Unitrunker.
kc4wsd
@GTR8000 I'm not going to tie up the SDS100 long term. I was just using it for "research," if you will. I like the way I can get information about the P25 transmitter site while using the GRE scanner. I'm a newbie with the '100 and wondered if it would do the same thing. Thanks again.
David
