johnsland8
I'm trying to connect to my SDS200 with the LAN connection using ProScan. My first question is, should this setup configuration be able to work:
My internet connection is through an Xfi Modem/Gateway. This has 2 Ethernet connections. I have my PC direct connected to one connection and my router is connected to the other. If I have the SDS200 connected to the router will my PC be able to communicate with the SDS200 through the router, even though my PC is not directly connected to the router?
Thank you!
Thank you!
