- Joined
- Jun 13, 2002
- Messages
- 6,092
I'm not 100% sure if this is the correct place for this, but it's the best I could find.
I have a 396XT that was loaned to a friend several years back. He no longer needs it, so it's been returned to me.
I'm going to use it for local scanning and need to update some of the programming. I'd also like to update the firmware as it's several versions old.
The problem is I can't get the computer and the scanner to talk to each other. I have the original serial programming cable and an IO Gear USB<->Serial Adapter. I downloaded and installed the latest version of the driver. Neither Pro Scan nor ARCXT will communicate with the scanner. Looking in device manager, I see an error message that there is no device connected and (Code 10).
I researched that and it seems to be a generic error. I followed the advice to change the Port number, but that didn't work.
As I said, I used this cable combination in the past, but now it won't work.
Does anyone have any suggestions on how to fix this? I suppose I could buy a new USB cable, but this should work.
Any help would be appreciated.
