Connecting Uniden BCD325P2 to upload data
MichaelC34
Boston, MA
so when I want to import again from PROSCAN i just check on and off what i want to import? i dont have to do the whole system again?
ProScan
Software Provider
Ontario, Calif.
Are you asking about importing from the RRDB to ProScan or uploading from ProScan to the scanner?
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
You're a premium subscriber. Import said trunked system via the Radioreference web service (page 19 of PDF manual I linked in Post #18 here
Database Import located in the Menu --> Database --> Import • • RadioReference Web (Subscription Required) - Imports data from the RadioReference Web Service.
As myself & others have suggested, read the manual & it will answer your questions
ProScan
Software Provider
Ontario, Calif.
i dont see quick key for the p25 trunk?
SQKs (Site Quick Keys) are assigned at the site level on trunking systems. I don't see any sites. You will need at least one site. Sites contains the trunking frequencies. Delete the trunking systems then go back to the RRDB Import and import the sites you are in range of.
MichaelC34
Boston, MA
i dont know how to do that could you please show me an example proscan please? I am interested in Cambridge Police they are on the trunk system TGID
ProScan
Software Provider
Ontario, Calif.
It's the same procedure as before when you imported the trunk system before. You must of unchecked all the sites. Just uncheck the sites too far away then import. The newly imported systems will append to the ProScan database so you won't loose the existing systems. If you haven't deleted the trunking systems that are missing the sites then delete those then upload to the scanner. When you upload to the scanner, then choose "Delete All Systems In The Scanner..."
