Connection drop after 5 minutes
Andrew033009
Andrew Davey
Hello
I got my ground loop isolator.. Everything seems to work fine, but at the five minute mark the stream shuts down.. It restarts a few mins later, I am using scannercast.. How can I fix this?
Deziel0495
If you have AVG antivirus it has been known to, at least in the past, cause issues with scannercast.
I personally use Proscan. RadioFeed by the same developer is free and is likely the best broadcast software out there in my opinion.
If you keep having issues, try a couple different things, including different software. Chances are if 2 peices of software have the same issue then it's a local issue, probably with your internet.
