Hi all,
When it comes to amateur connectors and their use; I'm good. I've found myself in a new domain with SMA/RP-SMA. The back of my GRE scanner has a BNC connection, no issue. I wish to try an Alpha wifi antenna on the back of the scanner. I have a BNC to RPSMA female (outside thread center pin) and the antenna itself is male with center socket. Will this combination function as a 'standard' antenna connection? With signal being center and shield being ground.
When we speak of reverse polarity, I somehow get the impression the signal is on the shield and the ground path is on center, which will *NOT* work.
I live fairly close to downtown St. Paul and my scanners "almost" do ok without the antennas. This is why I though the Alpha antenna might be worth a try.
My knowledge of the SMA world is extremely limited and I have the feeling I'm trying to back the car into the garage sideways
Angie
Angie
