Delivers1234
What is this? I thought it was a male sma to male uhf. I'm trying to connect ft2dr to base antenna.
Looks like a female SMA to a female SO-239 (AKA UHF)
The other trick you have to watch out for is the "RP" connectors, which are the reverse polarity connectors used on a lot of Wi-Fi gear. The outer shield will be one gender and the center pin will be the opposite. Really annoying if you get one by accident.
I think what you need is a male SMA to UHF. You could buy an adapter to make that cable work, but it's probably easier to just order the right one.
I thought male meant the connecter goes into...
This a adapter cable to connect HT radios like Baofeng and some older Wouxuns to coaxial cable. These radios use a "Reverse SMA connector" which is the opposite of a normal SMA like you'll find on Yaesu.
No, Baofengs, Wouxuns, Motorola and other simply have a male SMA on the radio chassis and the mating antenna needs to have a female SMA. A female SMA has external threads as your adapter cable and a socket or hole for the center. The male will have internal threads and a protruding pin. As mentioned by others, a standard connector sex is determined by the center pin with a protruding pin being a make and a socket or hole being a female. The picture posted by Coyote-Frostbite is a standard female SMA.
A "reverse" SMA is a much later invention where the male will have external threads like your adapter cable and a protruding pin down inside. The corresponding reverse female SMA will have internal threads and a hole or socket in the center.
prcguy
prcguy
You all are confusing me. I ended up ordering this but my coax cable is very stiff/sturdy. I'm afraid if I move the ht I'll start losing the sma connection from the ft-2dr. I didn't find the dongle kind that had about 5 inches of thin wire in between. I'll look for that one. It's for a temp setup until I get a base radio.
