I am looking for a base scanner that will do my county's new 700 P25 Phase 2 system this year and got some Christmas money to spend. I have been a Radio Shack / Whistler man for most of my scanners. I would be new to the Uniden club, and have a couple questions for you guys here.
1. Do I need a special cable to connect this scanner to my Windows 7 computer?
ShyFlyer & nick typed faster than I did.
The scanner comes with a cable, standard USB->USB Mini. (Note that you do NOT need the Uniden USB-1 cable, despite it's erroneous inclusion in the "Frequently bought together" items on Amazon's
page (the other of the trio is the GPS puck). You may need to download a driver for the included cable to work, but that is freely available.
2. Is there free software included, and if not- what is the best out there? ( I am use to WIN 500 software)
No 'free' software is included with the 996P2. However,
FreeSCAN does work on this product, and as the name implies, it is free. Your other, paid, software options are ProScan & ARC-XT.
3. How hard is this one to program by hand?
Manual programming instructions are available here:
Easier to Read BCD996P2/XT Digital Scanner Manual
The scanner can be fully programmed manually, through the keyboard. However, programming by software is much quicker, as you know from using Win500. Plus, you can see virtually all required settings at the same time, making it easier & quicker to spot and correct minor omissions and errors made during data entry.
4. Is it worth spending the extra for the 536?
To me, it was. The built in record function allows recording of unidentified
channels and talkgroups, especially when the scanner is unattended. (That can be done using a computer as well, along with the log & record options in FreeSCAN or ProScan, or the "Pro" version of ARC-XT; not available with the 'Basic' version of ARC-XT.) However, in the 536, or it's portable sibling the 436HP, that can be done using the scanner alone, no computer needed other than to review and catalog recordings once you are back home.
Also, the 536HP has a "true" narrow-band filter, which makes it handle certain systems better than a scanner without that. In general, overall comments indicate that the 536 does a better job on most simulcast systems, but that varies greatly by the specific system and location.
If using a GPS while traveling, the 536, along with the built in database, makes monitoring while going down the road very easily done. While you can use a GPS with the 996P2, you would need to include the location data when building a programming file for your projected route.
Thanks in advance, and Merry Christmas!
You're welcome.
Have a safe and enjoyable holiday season.
