n4voxgill
Silent Key
Nice console to handle up to 6 scanners
http://www.ncsradio.com/m_rx.html
The new NCS Multi-RX brings a new dimension to receive audio control and monitoring. With the Multi-RX you can choose which radios to monitor, where the audio will appear in the audio field (with two modes of operation to choose from), and it allows you to record any or all audio, utilizing Manual or VOX recorder activation. "Record Select" LEDs indicate which radio(s) are selected for recording. With the Multi-RX you can use headphones (or headset) or speakers or both simultaneously. "Busy" indicators for each radio are provided making it easy to identify which radio is active. Packed with functionality and flexibility!.
Monitor up to 6 radios simultaneously with the Multi-RX Switcher. Any or all of the six radios are selected with the Left and/or Right Channel pushbuttons in the “NORMAL” mode. In the “SPATIAL” mode radios are pre-assigned positions in the audio field and can be selected with the pushbuttons on the front panel.
