kc9pfh
- Joined
- Feb 14, 2023
- Messages
- 2
I often check into a 75 meter net for operators of classic radios using my FT-990, I know, not a vintage radio but it isn't modern either. The story I am about to relate is hard to believe, I probably wouldn't believe it myself but I swear it happened.
I went to check into this net on my 990 after tuning up my amp on a dummy load, an MFJ "cantenna" type dummy load. I was running about 800 W. I forgot to switch back to my antenna. As often happens I was able to hear net control quite well so I didn't initially realize I was still on the dummy load. I threw out my call and the NCO didn't hear me, so I gave my call again, then again, then again. Finally a station about 50 miles away heard me, asked me to repeat my call a couple of times and finally got it and relayed me in.
Initially I couldn't figure out why I wasn't getting out, but eventually realized my mistake. When I figured out what I had done I immediately switched to my antenna, gave my call and explained that I had been on a dummy load. After I did this a station from Indiana (I am in the Madison, WI area) came on and said he had heard me too.
The operating conditions here at the time were the 990, an LDG AT-1000 tuner, an AL80B amp and an two position Alpha Delta antenna switch with a 160/80/40 fan dipole connected to one side and a Hustler 5BTV vertical connected to the other. Feed line consists of 125 feet of RG-213 to the dipole and 100 feet of RG-213 going to the vertical. Both antennas are grounded to a 6' rod where they go into the house. Radio, tuner and amplifier are all grounded to a water pipe. The antenna switch was ungrounded.
I attempted to reproduce this with a friend of mine who lives about 25 miles away and he couldn't hear me, but another guy about 20 miles away did hear me put a CW carrier on the air from the dummy load.
Call me a liar but I swear this happened. Anybody ever heard of something like this happening?
