ps630
How do I contact Don Starr to get my software key?
fmon said:don@starrsoft.com
2 minutes to type a email addressK5MAR said:Look at the times, Dwayne. Frank was undoubtedly already writing his response when you posted yours. Just one of those flukes.
Mark S.
LOLunitcharlie said:depending upon what is happening on the scanners it can take me ten minutes to type a response....
Version 1.29 2004.02.29 13:00 PST
* Changed the frequency pasting code so that it will accept strings up to 11 characters in length, instead of the previous maximum of 10 characters. This will allow pasting of frequencies greater than or equal to 1 GHz with 6 decimal places. (The previous limit was incurred by legacy code – Win92 didn’t allow frequencies that high, so 10 characters was a reasonable limit).
* Removed a check for "printable" characters in alpha tags. This is to allow most of the actual characters available on the PRO-96.
* Added the "extended" frequencies to SR6 lockouts.
* Changed the copy-protection scheme so that it no longer depends on the user’s hardware. It is now dependent upon the user’s name and email address only. NOTE: If you are a registered user of Win96, this change may invalidate your current key. If this happens, send me an email and I'll issue a new key.
From Win96 upgrade page
Upgrading from a previous version
To upgrade, merely download the new version of the ZIP file and extract its contents into the same folder where you currently run Win96, overwriting the older version. If you're a registered user, your registration will not be affected.
